Home > Maintenance & Modifications > Using a trolley jack & axle stands |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
I use my jack either under the diff case or on the axle tube close the wheel and then leave enough room to get the stand under. 1999 Defender TD5 110
4th Aug 2014 8:15am |
Busboy Member Since: 23 Jan 2012 Location: West London Posts: 182 |
excossack
many thanks for the reply, I will give it a go at the weekend using the diff's all should be okay one thinks...... Steve |
5th Aug 2014 6:16am |
There is the issue that the diffs being off centre so when you jack it up the car will be off balance. 1999 Defender TD5 110
5th Aug 2014 8:15am |
I've been pondering one of these to go on my trolley jack
http://www.sealey.co.uk/PLPageBuilder.asp?...nID=101894 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
5th Aug 2014 8:24am |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
Nice bit of kit that...
If I had the money spare I'd get straight on it Defender 90 XS TD5 (03 Reg) |
5th Aug 2014 9:40am |
