Home > Technical > Chirp chirp, squeak squeak, clunk clunk |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5425 |
Prop uj's?
1st Aug 2014 5:24pm |
The repeated clunking when turning could be a cv joint on its way out
1st Aug 2014 5:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19621 |
Could be wheel bearings too..
1st Aug 2014 6:00pm |
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 |
Had this with mine recently. I was positive the noise was coming from the front. Turned out to be the rear prop UJ.
1st Aug 2014 7:22pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Super - thanks all, at least some areas to investigate.
1st Aug 2014 8:31pm |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 |
Jack the Landy up and check each wheel for play and roughness in the bearings. I'd be tempted to shove a screwdriver between the brake disc and the backplate to see if there's a small stone or Chipping lodged between them I've been called out a few times by relations because they had a noise from the front and found that it was a bloody stone stuck in there. The clunking on full lock could well be the cv joint
Uncas |
1st Aug 2014 9:37pm |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 |
Also had this recently. My money is on a UJ
7th Aug 2014 9:49pm |
Samblers Member Since: 29 Jan 2014 Location: Perth, innit Posts: 63 |
I had a very high pitched squeeky squeeky squeek at low speed for ages... usually over 'high frequency' bumps.
I traced it to the bonnet pivots, which are a metal painted pin in a plastic sleeve. Open your bonnet (or take it off) and squirt some lanolin on them or rub on some wax. HTH |
13th Aug 2014 8:30am |
