Home > Technical > 300tdi cut out whilst driving UPDATE
Page 1 of 3 123>
Culminator
This has happened twice now. On both occasions I've been driving along and the engine has simply cut out. No stuttering, just cut out and both the oil pressure and battery/ignition warning light have come on. Again, on both occasions, the car has started after a minute or so and continues to drive without a hitch. There has been a lapse of about 3 months and 500 miles between the two events, albeit on both times I had been on 40 minute journeys whereas I normally only use it for shorter distances.
Could this be anything other than a faulty lift pump solenoid that I've read about and is there any easy tests to diagnose?
Thanks!
Post #348541 31st Jul 2014 9:53am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Fuel tank breather plugged? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #348545 31st Jul 2014 10:06am
VeeTee
Netherlands
May be a faulty immobilizer? This thread may be applicable, though the location of the spider is different in the Defender (behind the instrument panel, as opposed to behind the radio panel in the Discovery 300 Tdi. Cheers, Vincent
MySite
Post #348550 31st Jul 2014 10:21am
g-mack
if it cuts out dead, it sounds electrical. might be worth getting a spare stop solenoid to carry, if it fails completely your not going anywhere! My 109 thread
my youtube channel
Post #348552 31st Jul 2014 10:27am
MichaelHead
England 2006 Defender 90 Td5 HT Tonga Green
Did this on mine , it's the alarm spider which is a black fag packet sized box in the battery seat box . I had a garage sort mine but apparently it just needs taking apart and re-soldering .
Post #348556 31st Jul 2014 10:56am
g-mack
have you got an immobilser? how many wires does the solenoid have on it? 1 or 3 ? My 109 thread
my youtube channel
Post #348557 31st Jul 2014 10:59am
Culminator
Thanks for the replays so far. It has the standard alarm activated by the key fob. I'm not so sure that has an immobiliser built in. 1 wire to solenoid.
Post #348561 31st Jul 2014 11:39am
Happyoldgit
What year is the vehicle?
I had a similar albeit occasional problem with a 300Tdi back in the day, I thought it was a loose connection on the stop solenoid but even after that was sorted the problem still occurred, a new solenoid cured it for good. Steve.
http://forums.lr4x4.com
Post #348577 31st Jul 2014 1:57pm
JWL
Stop solenoid, dodgy wire(squeeze up with pliers) or solenoid. The dash lights will come on because the engine has stopped and alternator isn't charging and the oil pump isn't pumping 'cause the engine isn't running.
Post #348590 31st Jul 2014 2:31pm
Culminator
Thanks guys, I know where to look now. Best place to buy a new stop solenoid? It's a 1998 by the way.
Mike Thumbs Up
Post #348598 31st Jul 2014 3:38pm
Culminator
Just had a look and seen that I do have the black box under the passenger seat, so I might investigate that as well Michael H. I'll fit a new solenoid as I guess they are relatively cheap and if it happens again! I then know it's very likely to be the "spider"
Thanks again all! Thumbs Up
Post #348604 31st Jul 2014 4:19pm
g-mack
ive just purchased a bearmach one for under £15 !!! it was this thread that made me think" hmm i should carry a spare"
one of the few things that will stop a tdi dead!! and very simple fix Thumbs Up My 109 thread
my youtube channel
Post #348610 31st Jul 2014 4:54pm
Culminator
Ok, so here's an update which I'm hoping might help other owners in the future. I replaced the fuel stop solenoid, an easy job and have driven the car on a number of occasions but the other week it cut out again on a 40 mile journey. Never seems to cut out on short journeys! Anyway, it started soon after and all was ok on the return leg.
Clearly my issue was not with the fuel stop solenoid, so I took out the "spider" unit to have a look and lo an behold, there's 2 if not 3 dry soldered joints in evidence. I've had these re soldered by Derek Alfrey and also purchased a by pass kit as a safeguard. It's all back together now so I'm hoping that resolves the occasional cutting out problem!
Post #356727 9th Sep 2014 12:20pm
MichaelHead
Just like I said Very Happy
Post #356789 9th Sep 2014 4:47pm
Culminator
Yeah hopefully Michael Thumbs Up
Was your very intermittent? I mean, perfectly ok for a while, then a cut out and then fine for a few more trips?
I really hope it's sorted now!
Mike
Post #356791 9th Sep 2014 5:18pm
Page 1 of 3 123>
