Home > Maintenance & Modifications > Front Truetrax lsd diff tyre wear? |
I have a true trac in the front axle and a Detroit locker in the rear axle. I had them first in my 1997 Camel Discovery and now in my 90 td5.
I do not see any strange wear on my tyres on both cars. My Discovery was used off-road but also my daily driver and as I am working in the oilfield it was making trips all over europe. So a lot off highway driving. I don't think you can blame tyrewear to the true trac diffs. The true trac and also the detroit locker want to go straight ahead when under power. With my 90 on and off throttle can easily make 30 deg difference in steeringwheel turn. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
29th Jul 2014 10:34am |
natyeo Member Since: 27 Jan 2013 Location: Bentham Posts: 136 |
Cheers for that , I will keep an eye on it see what happens , its had both truetraxs fitted for a few years but not done a big mileage, all the suspension bushesw are fresh and track rod ends all ok. 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
29th Jul 2014 8:23pm |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 |
Hi,
was using Truetrac front & rear for about 12years and 15.ooo kmīs per year with the RRC. I can say there was definately no abnormal tyre wear. They silently do/did their work, I never took any notice of them - other than in winter of offroad. No problems even though they had to cope with bigger 255/86-16s most of the time. |
30th Jul 2014 10:10pm |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 621 |
Does your hybrid have odd or mismatched suspension geometry - suspension lift or the like? JB
@Lodelaner Instagram Youtube greenlaning and other LR related content |
30th Jul 2014 10:14pm |
Just checked steering and axle front to back , running 2" llift, all seems fine, plus after setting tracking to parallel it is steering much better, not running caster correction arms on front , all bushes are fine, drop arm ball joint was u/s and replaced a month ago, tyre pressures all ok, re built crome ball bushes / bearings re built last summer too
Note had a "lock rite" diff lock (Similar to a Detroit locker but cheaper and really needed to be set with lighter control springs) in my series 3 years ago in the rear and that shoulder off my new XCL's on outer edge , if you set off quickly from a road end you could both hear and feel it pushing and biting 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb 2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
30th Jul 2014 10:46pm |
Doubtful the Truetrac would be causing it - was wondering if the negative castor from the lift coupled with the tracking could cause dithering around the straight ahead and shoulder wear. JB
30th Jul 2014 10:56pm |
Thanks for pointers, done 5000 miles plus with no sihns of odd wear , must have been tracking 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
3rd Sep 2014 10:37pm |
