Home > Maintenance & Modifications > Solid front brake disk V vented |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
No ABS and looking to replace it all in one hit makes it all a simple bolt on job. The current ones are original, and a few years old
29th Jun 2014 5:23pm |
when I did it I notice much better brake feel too 2002 90 Td5 Station Wagon
29th Jun 2014 5:42pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
Changed mine across from solid to vented on my 90. Much better.
Andy |
29th Jun 2014 8:39pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 540 |
What is the difference between the 110 and 90 rears is it just a bigger disc? Will 2005 90 XS 1954 86'' Series 1 tilt |
29th Jun 2014 11:16pm |
Different offset same diameter but much bigger calliper, 46mm piston as apposed to 41mm. The brake pads are quite a bit larger 2002 90 Td5 Station Wagon
29th Jun 2014 11:52pm |
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 |
Just to add some balance if you've not bought them yet... I was persuaded to try EBC Greens on one of our other cars and they are, without a shadow of doubt, the worst pads I have ever used. I found them to be very spongy feeling things (I prefer a "bitey" pad) that don't inspire confidence. Have given them 2,000 miles to make sure it's not an extended bedding thing but will be swapping them out for Ferodos very soon. |
30th Jun 2014 7:47am |
Agree with above. Green stuff pads are the worst I've ever fitted. Tried them for a thousand miles, then binned them. Nasty
Andy |
30th Jun 2014 8:09am |
Already brought the pads. These things are so subjective!! Land rover allegedly spend millions developing things, and then we assume we can improve on it! Ebc pads worked out £4 dearer than the Paigid I was going to use, so thought I'd give them a go. We'll soon find out
30th Jun 2014 9:10am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
I got my braided hoses from Llama 4x4 can recommend them 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
30th Jun 2014 11:18am |
Struggling with the braided hoses as mine is 2005 when things changed ,.......... But I had a thought The new calipers will be standard, so there is no guarantee that my old pipes will fit them either ? I suppose I need to check with the supplier ? Dose anyone know what the differences are???
30th Jun 2014 7:29pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
The flexi/braided hose is fastened to a short rigid copper pipe which in turn is connected to the caliper,so wont be any problem. Pov.spec,ftw. 2006, 110,TD5.
30th Jun 2014 8:36pm |
Aren't they supposed to be metric thread or something after 05? Is it just the caliper end ? and the other standard imperial ?
30th Jun 2014 8:55pm |
Dunno,I heard summut bout both ends being male or female,can't remember.But like I say the rubber/braided hose is connected to a short STEEL (not copper,doh!) pipe which uses a standard fitting to fit into the caliper. Cant find an image but a quick looksy underneath will explain all. Pov.spec,ftw. 2006, 110,TD5.
30th Jun 2014 9:14pm |
I'll speak with Brookwells tomorrow and let you know there thoughts I'm trying hard to avoid getting half way through the job at the weekend to find you can't complete it, so waste alot of your time
30th Jun 2014 9:18pm |
