Home > Maintenance & Modifications > Fuel gauge light blown- replacement? |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
Pretty simple - there are 4 screws holding the instrument panel on. (Two bottom, two side, it looks like there are more, but they don't hold it on)
Then pull the panel out far enough to get to the back of the gauges, and the light plug just slides out, then you pull the bulb. Easy 1998 110 300Tdi White Hard Top |
22nd Jun 2014 10:10pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Smashing
Will drop past halfords and get a replacement tomorrow and then should be able to fit in the evening. |
22nd Jun 2014 10:29pm |
landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134 |
Try replacing (and the other bulbs) with LED bulbs (available on ebay). Just done the ones on my 90, amazing difference, can actually clearly read gauges at night now!! 1959 Series 2 Ragtop
1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS |
23rd Jun 2014 6:36am |
If you're going down the led route, I can recommend the seller fizzmo on eBay, always been happy with their service. Good quality LEDs too 2002 90 Td5 Station Wagon
23rd Jun 2014 8:11am |
