Home > Maintenance & Modifications > Door cards rubbing on door frame |
Can you not loosen the hinges and adjust the doors and strikers accordingly? If you go through life with your head in the sand....all people will see is an ar5e!!
6th Jun 2014 10:31pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
I'm not sure adjust doors would help. I dont mean the outside of the door, B & C pillars, I mean the actual door frame. I will post a picture and hopefully that will explain better. 1999 Defender TD5 110
7th Jun 2014 8:52am |
It's quite common, I've mainly seen it on second row doors at the top of the card. I just repaint occasionally
7th Jun 2014 9:31am |
Its a PITA. I was thinking of adding some rubber strip around the outside to try and reduce this. 1999 Defender TD5 110
7th Jun 2014 10:00am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19621 |
Had a bit of this on the rear door too.
Check out the lower lip especially the latch side. |
7th Jun 2014 10:17am |
