Home > Technical > Light switch?? |
has yours got or had dim dip fitted
24th May 2014 8:44pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Er,yes and no,I had dim dip recently,but assumed it's a fault causing dim-dip or a fault that stopped it working,mostly I don't have dim-dip . Pov.spec,ftw. 2006, 110,TD5.
24th May 2014 8:58pm |
think your best off to disconnect the dim dip first
24th May 2014 9:03pm |
Just simply unplug the resistor??As simple as these pics suggest,or remove relay behind binnacle and rewire the relay holder?? Cheers.
http://www.defender2.net/forum/topic9328-30.html Click image to enlarge Click image to enlarge Pov.spec,ftw. 2006, 110,TD5. |
24th May 2014 9:25pm |
