Home > Maintenance & Modifications > Chequer plate wingtops - fit with gasket or not? |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
I fitted mine without the foam and they have been fine. have you thought of fitting the plates with stainless steel fasteners with countersunk heads in my opinion they look so much neater, you could paint the tops of the fasteners black.
20th May 2014 12:32pm |
Go to a garden centre that provides a marine service like Maidenhead Aqautics and buy a metre or so of butyl pondliner. This makes an absolute ideal gasket. My chequer plate is fitted with gaskets all of them supplied by the relevant suppliers. On everything else I have used pondliner to great effect.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2014 12:38pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5423 |
No point in fitting it. Water gets in a knackers wings any way.
Andy. |
20th May 2014 1:41pm |
What gaskets or chequerplate? If done correctly with gasket and wet assembly of the fasteners your comment is 'rot' in itself! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2014 3:20pm |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Ok fitted with pond liner under it. I also put grease in the holes prior to rivetting. Thanks for the advice much appreciated. 110 Hardtop
20th May 2014 6:19pm |
Just out of interest and I hope not sounding to daft but what does the foam actually do and what is 'wet assembly' |
20th May 2014 7:01pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 513 |
I hate tread plate, but if I was fitting it I would paint both surfaces in waxoyl - if you have seen the mess after tread plate is removed the reasons why are humblingly honest
20th May 2014 7:24pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
I would and have fitted mine with the foam provided.
I never noticed any issues when fitted 2004 TD5 Defender 90 xs station wagon |
20th May 2014 8:37pm |
Gaskets when compressed will prevent the ingress of dirt and moisture and prevent the possibility of corrosion and abrasion. Wet assembly is when you fit a fastener it is smothered in sealant or an anti corrosion medium, the excess is wiped away after tightening. This can give an effective seal and prevent the onset of dissimilar metal corrosion through the electrolytic interaction of two different metals when wet. You did ask! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2014 9:12pm |
