Home > Off Topic > Diagnosis please - wheel bearing on an Audi |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
I've never had a wheel bearing go (had them changed but never heard them) so I need some advice.
I have to drive about 1500 Km next week and the A2 has started making a low humming sound when steering left or driving straight on. Steering right makes it disappear. It's getting worse and you can feel it through the gas pedal at certain speeds. Steering hard left (not right) at some speed makes a light knocking sound. The tyres only a couple of years old, look in good condition and are evenly worn. Can I be (almost) 100% certain it's a front (right?) wheel bearing? No Audi garage has time to do the work so I need to get the parts for our local one. Cheers for any insight Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th May 2014 9:36am |
Whatever you do to one side it is 'good practice' and the prudent thing to carry out on the other to prevent undue stresses on the older item. My advice would be to do BOTH fronts.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2014 9:38am |
Cheers. So definitely bearings? Tell someone you love them today because life is short.
20th May 2014 9:41am |
Sounds like it....have you jacked up the front end and rotated/spun the wheels and see if there's any lateral play in the wheels themselves?
It can be very difficult sometimes to detemine whether it is front or rear due to sound resonation through the vehicle. Jacking it and doing the above may give you a pointer. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2014 9:47am |
I checked about a month ago when I put the Summer wheels on but couldn't feel any difference between L and R (slight play in both - not sure what's normal). It's got a lot worse since then so I'll get off my backside and check again tonight Tell someone you love them today because life is short.
20th May 2014 11:40am |
Thanks guys - car is booked in Tell someone you love them today because life is short.
20th May 2014 1:59pm |
All done today - picked it up and an incredible difference, like a new car.
Only downside is they need a part to fix the ABS/TC tomorrow... and an A2 without TC in the rain is like a go-kart on a skid-pan Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
26th May 2014 5:28pm |
