Home > Maintenance & Modifications > Steering UJ's |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5423 |
Are you talking about the uj's on the shaft under the bonnet from steering colum to steering box?
If you are, the easiest way is to buy the complete section that contains both uj's and the joining section. Then it is just a case of removing bolt from top and bottom clamp then a quick fight to get it out, new one in tighten, test. Simples. I got mine from Devon 4x4. Andy |
18th May 2014 9:30pm |
steering lock on and wheels on ground then with bit of luck steering should be back in same place .
make sure uj's are pushed right on splined ends ( column and steering box ) when you put bolts in |
18th May 2014 10:16pm |
souster4 Member Since: 11 May 2014 Location: West midlands Posts: 153 |
Cheers guys. I bought replaceable UJ's.
With engaging the steering lock, will I manage to loosen the pinch bolts? Is there anyway i can put it back together wrong, incorrectly on splines etc? |
20th May 2014 4:45am |
