Home > Maintenance & Modifications > Uneven brake pad wear
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
I am almost 30k mi and screeching coming from the brakes. On inspection, both the front and rear left brake pad is due but the right ones are only about 50% through... Is there some setup issue or something I should check? Shouldn't they wear down evenly?
Post #330943 14th May 2014 9:15am
jimbob7
Could be piston/s sticking slightly,are the wheels excessively hot after you have driven it. Pov.spec,ftw. 2006, 110,TD5.
Post #330949 14th May 2014 10:20am
ronwong
I can't tell if they are excessively hot, but they are generally hot.
Post #330950 14th May 2014 10:28am
