Home > Maintenance & Modifications > Does anyone have a steering wheel puller I could borrow? |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5743 |
My method was to undo the nut so it almost off, and then from behind hit the wheel at 12 o'clock 12:30 and quarter to and quarter past and then repeated then work backwards quarter to, 12:45 , 12:30 12:15 etc.
Sorry no puller 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
11th May 2014 3:10pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
Tris I got one here I made. Very simple mate more than willing to post it tommorow for you CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
11th May 2014 3:15pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
excossack - thanks for the suggestion, but I've tried and tried 'til I'm blue in the face and it just won't budge at all.
Chris - you have a PM - thanks 2005 Td5 | 90 Station Wagon | Tonga Green |
11th May 2014 3:31pm |
FBH ?
Good luck! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
11th May 2014 3:43pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3614 |
Have you tried getting someone to pull the wheel towards the interior and giving the shaft a smart hit in the opposite direction? (avoiding damaging the treads or anything else I would use an alloy or copper drift in the centre of the shaft when I did this) DEFENDER 90 TDCI XS,
11th May 2014 4:36pm |
maybe you tried this already
loosen nut but leave on few thread , sit in drivers seat put hands each side of wheel and with your weight pulling on the wheel , rock the wheel from side to side (not turning the wheel ) so weight of pull lifting you out of seat is on one side then the other straighter your arms are the better (not so easy in a defender to get your arms straight ) |
11th May 2014 4:45pm |
Grey110 Member Since: 20 Jun 2012 Location: Delft Posts: 35 |
This summer I bought a new steering wheel and to be sure I had the right steering boss I changed the steering wheel in the parking lot.
First loosen the nut as much as possible but leave it on. As a tool I used two bolts and two big washers to pull on the steering wheel. Tighten, pull a bit and thighten more etc. Martin Previous 2003 Defender 110 Hardtop TD5 2004 Defender 110 Station Wagon TD5 - Libyan Sand 2005 Discovery 3 - V8 - Black |
11th May 2014 8:05pm |
