Home > Maintenance & Modifications > TD5 wiring diagrams |
trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 102 |
Can anyone help ? I intend to fit a pair of front fog lights and need to know where I can get TD5 wiring diagrams. I have a Haynes Defender manual, but this does not cover the area's I require. Also where is the best place to buy the correct console switch.
5th May 2014 10:36am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Hi Can't help with the wiring ( I only have Puma) but Dan at Duckworth parts can help with original LR switches
I used a Heated seat switch for my rear view camera and it was about five quid Edit: This site has the TD5 workshop manuals in PDF http://www.landroverweb.com/landrover/pdf-land-rover-manuals/ |
5th May 2014 10:41am |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
Alternatively, send me an email address, and I can send you the PDF file. It wasn't me! |
5th May 2014 10:50am |
td5 2002-2007
Wiring diagram http://1drv.ms/1ninSKh Electrical Library (connectors lay-out and pin-out) http://1drv.ms/1nio24i td5 1999 Wiring diagram http://1drv.ms/1niobEW Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
5th May 2014 12:34pm |
...and I'm still searching for that electrical library in ENGLISH. It wasn't me!
5th May 2014 1:02pm |
Thank you all, the information will be very useful.
5th May 2014 7:18pm |
