![]() | Home > Maintenance & Modifications > inside out |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
There are some plugs and grommets in the bulkhead where cables go through. There's room for more, I added some for my external engine temp. check.
May on the Puma they are on different places, but here they are on the earlier Defenders: I used nr. 5. ![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346 ![]() ![]() ![]() |
Aha. Thank for that.
More investigations. ![]() |
So found the big fat grommet with various cables already in it and there's room still for what I need.
Problem is what is the best way to cut a nice round hole for a half inch conduit to go through - just use a Stanley knife and be careful? |
Drill and be very carefull
![]() Really? With a has bit? I'm weeing myself just thinking about it? Will have to have a look cos not sure I can get a drill bit to it and can't get the grommet out to drill either - have a look though. |
You should aim for a hole that is smaller than whatever it is you are feeding through. Take one sharp knife [Stanley blade or scalpel] and carefully cut a small X in the rubber, feed the cable through and then re-seal with mastic.
BUT can you not squeeze the additional cable through the existing hole in the grommet - a little silicone grease will help get it through. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Thanks Steve....
It's started, I've already generated a hole in the large grommet adjacent the brake cylinder and hopefully it's large enough. The cables are going to be small but it's the plugs on the end that'll be the problem. Will hopefully resolve tomorrow now. I'm running the phone leads for my sub woofer ![]() |
Munch90...looked at this but once in the he area of the cubby box couldn't decide on where to go next?
My plan is to run the phono and switched live to down by the gearbox where I will pick up a permanent live and run to the rear and then back in for the sub. |
where is sub going to be
Under the mid row seats
why not on back of cubby box
Personally don't like it there.....in my eyes looks like an after thought.
ok
I would say with putting it under a seat 1 its not going to be as good with sound hitting a flat surface (I know others have done it and say ok but more space and air around is going to be better 2 cone facing up is going to fill with dust and crap 3 getting wires to it 4 some of them have a remote gain control which you need to be able to get at while playing 5 power can be taken from under drivers seat fuse box easier just my thoughts |
Munch90..... can't argue with at of your comments however with it being a sub I suspect / hope location is less critical. in terms of wiring I like a challenge
