Home > Maintenance & Modifications > Spraying at home |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3616 |
I have sprayed whole cars at home in the past, used both cellulose and two pack and both with a small compressor and cheap spray gun and got fairly good results. It is time consuming and messy. If you have a big indoor space that helps, I had to do it outside on a hot still day and then wheeled the cars carefully into the garage. It is satisfying if all goes well, conversely it can be very frustrating when it does not and you get runs or reactions. I would recommend getting a small spray gun and trying it on some simular materials to see if you are happy with the results before going for it on the car. DEFENDER 90 TDCI XS,
3rd May 2014 6:50am |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 |
I resprayed my Defender when I rebuilt it just doing a panel at a time. All I had was a compressor, spray gun and a dirty garage and yet it came out really well.
I got the compressor and spray gun from Machine Mart. I bought their own brand 'Clarke' compressor. It is a 50ltr air tank and gives 6cfm of air flow. It is an oil free model so as not to get oil contamination in the air and therefore paint. A larger tank would have been good, but 50ltr was ok. The spray gun was also a Clarke HVLP gravity fed gun. Again this worked just fine even though it was £30 and not £300 like the pro guns. I got the paint from an online trade paint supplier and the easiest stuff I have found to use is the Mipa system. It is a water based base coat and then an acrylic clear coat. Fast drying at normal air temp and not too toxic so it is great for home use. Really pleased with the results though - they look professional. |
3rd May 2014 8:16am |
Solid colours are somewhat easier to get an even finish than metallic. Cleanliness is a must - the key to a good finish is good preparation, it's the prep that takes the time. Some paint systems are more forgiving than others, don't rush it, practice makes perfect. I've managed some good results with HVLP systems esp with old fashioned cellulose but a decent gun, largish compressor and good filtration make it easier. Steve.
3rd May 2014 8:31am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Depends how good a finish you want.If your car is a 20 year old banger go for it can't make it any worse,if it's fairly new there is a good chance it wont look right and I would leave it to a pro.Of course I'm being kind,I've known quite a few peeps paint their cars in the past thinkin they done a good job . Pov.spec,ftw. 2006, 110,TD5.
3rd May 2014 9:08am |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
erm excuse me! not all 20 year old cars are bangers!! although to be fair mine is! My 109 thread
my youtube channel |
3rd May 2014 10:14am |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 439 |
I'd like a presentable finish but having had defenders for years I know that that doesn't have to be amazing but the metallic finish on the Epsom would have to be passable.
I tinker with the odd Land Rover here and there and it would be nice to not have to rely on a third party to do the bodywork. I think the first step is to bin my small compressor and get a better one and go from there. I guess I need to so some serious reading up on paint while i'm at it. |
4th May 2014 1:08am |
