Home > Maintenance & Modifications > New Bonnet Release Cable |
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 |
I've just got a new one for mine, think it was about £7, I got it from my local supplier but believe its a Britpat item.
The handle bit is in the cab, left side of clutch pedal, I've not looked under the bonnet and its chucking it down at the moment |
29th Apr 2014 5:48pm |
Benzini Member Since: 26 Apr 2014 Location: Sleaford Posts: 10 |
cheers for the quick reply.
Yeah I've got the new cable mechanism but it didn't come with the small metal bit at the end. I know where the cable is supposed to go in the cab but there's no bracket for it... I think originally they were spot welded on? |
29th Apr 2014 5:50pm |
This is where mine fits near the release mechanism, not sure how you would fix it without the 'nipple'
Click image to enlarge[/URL] This is the cab fixing bit Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
29th Apr 2014 6:01pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
C01.225 GRILLE, TOP PANEL & BRACES-CABLE BONNET RELEASE
KIT-BONNET LOCKING Part number: STC927 |
29th Apr 2014 6:34pm |
many thanks, that solves that problem.
Any idea what to do about the bracket though? |
29th Apr 2014 7:38pm |
Bolt a piece of angle iron in the place where the original went?
29th Apr 2014 8:09pm |
not sure if you got nipple sorted , you could put a small bolt down though the hole in the bonnet latch lever with small hole drilled through it , pass cable through hole and lightly tighten nut against the cable
you used to be able to buy universal cables with a bracket included Last edited by munch90 on 29th Apr 2014 8:16pm. Edited 1 time in total |
29th Apr 2014 8:15pm |
Same idea you had on the old pushbike for adjusting the brake cables
29th Apr 2014 8:16pm |
Both good ideas, I'll let you know how I go!
that's it
29th Apr 2014 8:44pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5433 |
You could also use the internal section of an electrical chocky block
Andy |
29th Apr 2014 8:55pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
wire cable end stop on flebay Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
29th Apr 2014 9:09pm |
So I take it I should fabricate something to go off of the large bolts to the left of the clutch pedal.
Also, I can't see anywhere obvious where the cable is supposed to go through the firewall? Click image to enlarge |
30th Apr 2014 7:48pm |
Looks like mine is riveted or welded in place. The cable goes through to the left of the clutch pedal
Click image to enlarge[/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
30th Apr 2014 8:14pm |
