Home > Technical > Puddle under fuel filter |
make sure filter is twisted right on , sometimes the last bit can be tight
21st Apr 2014 2:19pm |
I had the same problem and realised at the last service they had fitted a non genuine fuel filter and the rubber had shrunk so fuel was slightly weeping from the seal. I fitted a genuine fuel filter and tightened properly and the problem was solved
21st Apr 2014 2:44pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Thanks chaps, will have a look. Last service was by an independent who claim to use genuine, so will check
21st Apr 2014 3:52pm |
hmm..... Britpart or more fondly referred to as S**tpart
Will have to dig out my invoice to see if they claim to fit genuine LR which I seem to recall they did say they did Wish I had gone to the dealer now as I only went indy to support them |
21st Apr 2014 5:15pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
Kmac, only shi** indy's will use sh** parts. Anyone with experience will know britpart filters are crap more often than not. I will only use genuine or oem filters as I don't find anything else is up to scratch and the price difference is so minimal it's not worth skimping.
Hope they sort it for you and good on you for supporting local garages (although it would seem you picked the wrong one ) |
21st Apr 2014 5:23pm |
Well I have checked their website and the invoice and they haven't put it in writing that they use genuine parts.
Service was in Nov 2013 so I'm just going to buy a genuine LR filter and replace it myself Indy is Graham J Goodyer, was recommended on this very forum |
21st Apr 2014 5:30pm |
I wouldn't bother getting main dealer part , just go for a good make , mahle,wix,mann,fram,coopers,stanadyne ( not crossland gone down hill used to be good )
make filter head is clean before removing filter , very easy to knock big lump of crap on to new filter when fitting |
21st Apr 2014 6:01pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6265 |
Word of warning....might be worth checking before driving as I know someone who didn't notice the puddle and a mile down the road broke down cos filter was empty and after that was pig to bleed fuel lines
21st Apr 2014 6:09pm |
and just in case , fill new filter with clean diesel before fitting
normally they leak because they not tightened the last notch as you twist it (last bit can be quite tight ) |
21st Apr 2014 6:16pm |
Thanks munch and caterham
Are they hand tightened or is there some sort of tool like the ones for oil filters? |
21st Apr 2014 6:23pm |
by hand with a bit of rag round to get a grip on it as it will have bit of diesel down the side of it
can use a oil filter tool ( the type that have a handle and metal strap and grip when you undo or do up ) BUT BE CAREFUL IF USING TOOL AS THE HOUSING ARE PLASTIC AND COULD TWIST IT RIGHT ROUND KNACKERING NEW FILTER AND HOUSING good hand grip is normally all that's needed |
21st Apr 2014 6:31pm |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
This might be a silly question but can`t you fit a ford one it`s a transit looking filter head after all. Excuse the spelling I`am better with spanners and wires.
21st Apr 2014 9:06pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
If you,re struggling to get a grip on a fuel filter or oil filter use a bit of wet and dry paper with the abrasive side against the filter and your hands will be able to grip the paper side, This is useful on Td5 oil filters where there is restricted access. 2005 Td5 90 XS
Steve |
21st Apr 2014 9:12pm |
transit ones are a bit longer and you can't fit the metal cover guard back on ,
but yes it's the same fitting |
21st Apr 2014 9:16pm |
