Home > Technical > Bolt that connect alternator cable to battery |
think your find the alternator cable goes to the starter then feeds battery back through main battery lead , the cable your saying about (the smaller one that bolts to battery terminal ) goes to fuse box under the drivers seat .
but the cable bolt is 10mm head , m8 thread size , 8mm hole in ring |
12th Apr 2014 12:30pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Thanks munch. Just that there's another threaded hole next to it to which I am planning to connect my headlight relay loom. Will get an M8 bolt and 8mm ring crimp/solder connector
12th Apr 2014 12:33pm |
yes no problem ,that's what I done use the extra hole
12th Apr 2014 12:37pm |
