Home > Maintenance & Modifications > Keep it simple: LED headlights and too much technology
ZeDefender
Just to prove a point, my LED headlights just up and died... because the 12V to 24V stepper that I so cleverly installed to give them a bit more juice, failed. It lasted precisely one month.
Fortunately I was able to switch them back to 12V quickly (thanks Brendan for suggesting the connectors) but I have learned my lesson Embarassed
To paraphrase Brainiac: "I do these stupid things so you don't have to" Whistle Tell someone you love them today because life is short.
Post #322645 9th Apr 2014 2:37pm
ericvv
Post #322691 9th Apr 2014 5:12pm
Grey110
Netherlands
Yes, I recently had a similar problem. Lights didn't work, had to check all modifications....
Question Did you actually get a benefit with the stepper? I imagine that the LED lights contain a similar stepup/down circuit to give constant voltage to the LEDs. If not you would have killed the LEDs because a LED on its own can be damaged by high voltage. Martin
Previous 2003 Defender 110 Hardtop TD5
2004 Defender 110 Station Wagon TD5 - Libyan Sand
2005 Discovery 3 - V8 - Black
Post #322692 9th Apr 2014 5:14pm
ZeDefender
Even with the new headlight harness I got a bit of flickering sometimes (nothing like as much as before) due to undervoltage (think all my wiring is crap), so I thought I'd step up the voltage to eradicate it completely. Worked brilliantly... until it didn't Rolling Eyes
*Edit* the LEDs (Speaker 8700s) are rated 12V/24V and the stepper had a solid 24V output (until it died). Light output was the same with either voltage, it was just the flickering I was trying to fix. Tell someone you love them today because life is short.
Post #322699 9th Apr 2014 5:32pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Do the lights flicker when the car is standing still with engine off, i.e no engine vibration?
Sounds to me like you have dodgy headlight wiring with a loose connection somewhere (possibly the switch or H4 sockets). This could still cause flickering even with a headlight relay setup - the relay may be less sensitive to the voltage drops from the loose wiring... hence less flickering
A 12v to 24v converter may also have capacitors built-in that stabilized the power supply, which is why 24v appear to work.
Post #322741 9th Apr 2014 8:07pm
ZeDefender
Nah - they flicker when the car is standing still and the battery isn't completely topped up. It's completely voltage-dependent - gets worse when the glowplugs come on and goes away once the alternator is doing its job. My 110 just seems a bit over-sensitive to this problem Rolling Eyes
Bless our Defenders, they all have their quirks Laughing Tell someone you love them today because life is short.
Post #322761 9th Apr 2014 9:09pm
dgardel
Italy
I switched to Nolden for solve the problem Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #322811 10th Apr 2014 6:50am
leeds
dgardel might have suggested the solution Thumbs Up
Speaker 8700's can flicker for several reasons
Quote:
Q:
I have LED headlights installed on my Jeep and they’re flickering. Why is that and what can I do about it?
A:
There are several possibilities for the flicker:
Cause: A connection may be loose.
Solution: Double check the wiring to confirm a tight connection in all places.
Cause: Your H4-H13 wiring harness may need replacing.
Solution: Replace your wiring harness with a new one.
Cause: Newer Jeeps utilize something called “Pulse Width Modulation” (PWM) which may cause your J.W. Speaker LED headlights to flicker. A simple explanation of PWM is that the Jeep’s electrical system “pulses” power to the headlights at a very high frequency. With the original stock headlights, you don’t notice any flicker because they aren’t responsive enough to turn off & on. LEDs, however, are extremely responsive, so the pulses created by the PWM can result in a visible flicker. All brands of LED headlights are subject to this same phenomenon.
Solution: The issue of PWM lies with the Jeep’s electrical system, not with the headlight. We do have an Anti-Flicker Harness that addresses PWM-based flickering.
I think we can rule out Pulse Width Modulation on Defenders
ZeDefender seems to think it voltage dependent now lets look at the specifications
JW Speaker 8700's Input voltage 11.4- 32V DC
Nolden 7" Input voltage 9 - 32 volts DC
Speakers will be more sensitive to a low voltage then Noldens
Brendan
Post #322888 10th Apr 2014 2:35pm
dgardel
Italy
I know, I discovered that the problem of flickering of the JWS depended on the voltage of the battery, especially if the car was stopped for a bit 'of days.
The first type of JWS did not do it, it is a problem of 8700 Evolution Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #322902 10th Apr 2014 3:29pm
ericvv
^^ As long as your battery is ok, the Landreiziger loom should solve any Voltage losses which we all have with the standard set-up of all juice running via the switch. I believe this can reduce the Voltage arriving to the headlights easily by 1V, so you can arrive under the treshold for the Speakers to function correctly.
In my case the Speakers would flicker if I would turn them on with the contact on, but with engine not running yet, so when no power is generated by the alternator.
Now after the Landreiziger loom has been installed, the flickering is all history as my now 5.5 year old original battery still holds a charge at rest of well above 12V.
I guess a battery which at rest is not able to hold a charge of 12V or more is up for changing anyway.
The loom works and does what it is supposed to do, including avoiding the switch to melt, that is for sure. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #322907 10th Apr 2014 3:43pm
K9F
leeds wrote:
Nolden 7" Input voltage 9 - 32 volts DC Speakers will be more sensitive to a low voltage then Noldens Brendan
Brendan, I am also possibly interested in swapping out my JWS for a set of Noldens IP6K9K it doesn't get any better. Looking at the Nolden newsletter for the 7th generation of their 7" LED headlights it states voltage figures of 12-24V. May I ask where you are getting the voltage input figures from please as this would be yet another reason to swap perhaps?
Here is my link.....Thank you.
http://www.noldengmbh.de/en/company/news/45-7-led-headlight If you go through life with your head in the sand....all people will see is an ar5e!!
Post #322908 10th Apr 2014 3:43pm
ericvv
According the Nakatanenga website they work between 9-32V
Technische Daten:
•Abmessungen in mm: 177 x 152
•Anzahl LEDs: 5 x Osram Automotive
•Leistung (Abblend-/Fernlicht): 32W / 39W
•Spannung: 9-32V
•Lumen berechnet: 1880lm / 2400lm
•Lumen gemessen: 1550lm / 1700lm
•Referenzzahl (pro Scheinwerfer): 12.5
•Befestigungsschema: PAR56
•Zulassung: ECE, SAE
•Frontscheibe: UV-resistentes, hartbeschichtetes Polycarbonat
•Gehäuse: in Alumium-Druckgußtechnik gefertigt, leicht, korrosionsfrei
•Wasserdicht: nach IP6K9K Norm, dokumentiert durch 480 Stunden Salzsprühnebeltest You never actually own a Defender. You merely look after it for the next generation.
Post #322912 10th Apr 2014 3:56pm
ZeDefender
I think if my Speakers ever die or corrode badly (hopefully not for a few years yet!) I will go for Noldens or something similar. I don't like the way the alternatives look c.f. the Speakers but in the end the Nolden specs win Rolling Eyes
Mind you, as far as customer service goes, I think Mobilecentre/Speaker will be tough to beat Thumbs Up Tell someone you love them today because life is short.
Post #322941 10th Apr 2014 5:57pm
ericvv
I think the specs as they are given are really an apples and pears comparison. No common denominator in that, and until today nobody on here really has been able to give any convincing evidence of which is better based on the numbers. So I still think the best is a side by side comparison, so maybe you remember the below... Result is pretty close I would say...
Eric
http://www.defender2.net/forum/topic21619....ker+nolden You never actually own a Defender. You merely look after it for the next generation.
Post #322942 10th Apr 2014 6:07pm
ZeDefender
From the specs, I mean:
1) Water ingress
2) Corrosion
3) Flickering
4) Beam pattern, e.g. high beam
I love my Speakers but the lenses were wet inside within a year and corroding soon after (due to contact with the bezel and water inside). They still flicker, even with the new harness and even though the voltage at the terminals is well above 11 volts. I find this short-sighted of a manufacturer that should understand car batteries and wiring. The low beam has a strange pattern nearer the vehicle and the high beam only lights the road far ahead. In particular there are some "groovy" (and I find distracting) rainbow effects at the fringes.
I haven't owned Noldens so I can only go on other info, but one comparison I saw showed a much more even beam pattern for the Noldens. They also claim to go down to 9 volts and are supposed to be more waterproof (has anyone had condensation inside them?) and I assume less likely to corrode.
HOWEVER as has been pointed out before, the 5-year guarantee and service for the Speakers is second to none and I am addicted to the way the Speakers look Bow down So, I'll bide my time and wait for all the problems with the Noldens to surface - until then, I'll drive around at night with my Speakers shining, and feeling like a king Mr. Green Tell someone you love them today because life is short.
Post #322946 10th Apr 2014 6:32pm
