Home > Maintenance & Modifications > OEM NAS step bumper 240Nm |
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 |
My wife says I have OCD... She's wrong of course I just like to do things properly, if I didn't I'd have someone else do it!
All torque setting followed... If i do tow... They will be checked afterwards too... |
23rd Mar 2014 3:01pm |
wildrover Member Since: 09 Oct 2011 Location: Notts Posts: 51 |
How much is that bumper and where did you buy it from.
2nd May 2014 12:03am |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 674 |
Torque required to load a bolt increases significantly with bolt diameter, as there is a squared function since the load acts over the area. For M16 8.8 grade 240Nm seems sensible weareas for an M10 it may be 45Nm.
M16 bolts have 24mm AF heads and the spanners are significantly longer than the 17mm AF spanners required by an M10 bolt, there is a good reason why they are longer you need a lot more torque to tighten them. But the lubrication and surface finish of the bolts & nuts is often overlooked, a phosphated bolt may only require 75% of the torque to provide the same residual bolt stress as a black bolt. The joint design must also be taken into account, its the bolted joint subject to vibration, cyclic load, thermal cycling. is there sufficient bolt length to permit elongation and hence induce some elasticity into the joint design. ok im boring myself now, in summary... for a pair of M16 8.8 grade bolts that are holding a hitch on to vehicle that may well be dragging 3.5Te of trailer with 175Kg of nose weight 240Nm seems correct, a recheck of torque after 1 month is also a good idea. Good night Richard 130 Puma HCPU with an Artica 240LR Demountable Camper Last edited by RFT on 3rd May 2014 2:25pm. Edited 1 time in total |
2nd May 2014 12:54am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16945 |
24mm (not 25) for a standard ISO M16 hex head. |
2nd May 2014 9:27am |
yes 24mm fat finger on key board syndrome 130 Puma HCPU with an Artica 240LR Demountable Camper
3rd May 2014 2:25pm |
