Home > Puma (Tdci) > xs heated seat element (round thing)
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
On the xs's heated seats, on the back part near the bottom is a small round disc, its part of the heated seat element and is noticable when you look at the outer fabric. I've had a quick look, fiddled about with it (hands under the fabric) and tried to push it into the foam but had little success.. now the seat doesnt warm up!
is the round thing it a connector i've broken?
james
Post #314030 6th Mar 2014 8:04pm
rich
England 2004 Defender 90 2.5 TD HT Barolo Black
there is a wire going into and one coming out you may have broken one of the wires which will stop both the back and base working as they both work as a circuit together
Post #314045 6th Mar 2014 8:39pm
MR_JAMES
I think its some sort of sensor.. power goes in but not out. For the time being i've cut it out and its working. Need to find a replacement.. might try maplins.
Post #314233 7th Mar 2014 12:42pm
dgardel
Italy
look here
http://www.rangerovers.net/repairdetails/s...grade.html
May be this is your switch
http://www.digikey.com/product-detail/en/c...ND/2195521 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #572963 23rd Oct 2016 10:44pm
