Home > Puma (Tdci) > Which Snorkel
Matthew_Mills
SailingTom wrote:
Matthew_Mills wrote:
Has be be a standard LR for me... Cool
Visibility is marginally worse
Matthew, Ive just purchased a genuine Land Rover one like your for my next defender (at a particularly bargain price Wink ) Could you tell me how it secures to the wing. Do holes have to be drilled like I have done with safari ones in the past?
Cheers Tom Thumbs Up
Two holes drilled in the A post into which a bolt cuts it's own thread... Then two holes drilled in the wing with Rivnuts inserted - they are like a captive nut crossed with a rivet!
See in striations below: -
Post #313162 3rd Mar 2014 6:54pm
Lewisgregory8
2014 Defender 90 Puma 2.2 HT Fuji White
instructions are the same as the Mantec RAI
Post #313167 3rd Mar 2014 7:01pm
Matthew_Mills
Yep the LR version is made by Mantec for LR...
Post #313169 3rd Mar 2014 7:04pm
SailingTom
Nice one, cheers for that guys should make it easier Thumbs Up Defender puma dormobile camper
Post #313182 3rd Mar 2014 7:22pm
Defpuma
United Kingdom 2013 Defender 90 Puma 2.2 HT Santorini Black
I went down the mantec route just because I prefer the way it looks. Was easy to fit and as far as I am concerned, hasn't effected vision out the front or the side at all.
Post #313212 3rd Mar 2014 9:10pm
If you're looking for a proper water resistant snorkel then the Safari is probably best out of the box. If that's not a prime concern, or you're prepared to put a bit of effort in to improve the sealing, then it basically comes down to which one you like the look of.
The only proviso to that is that Pete Bell has demonstrated on his rolling road that the modern looking Mantec (known as the plastic jobby!) saps a significant amount of hp.
Personally, I went with the plastic Mantec one as used on the G4 vehicles. I like the combination of the traditional look and modern materials:
 Darren
Post #313244 3rd Mar 2014 9:57pm
BigWheels
I like that too. Thumbs Up
Point to consider, the rigid tube snorkels might not accommodate a roll cage if you decide to fit one in the future.
Which is the quietest? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #313319 4th Mar 2014 2:08am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Thanks all for the replies, I got to say that I like the Mantec as fitted to the G4, as you say kinda traditional but modern. 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #313416 4th Mar 2014 1:56pm
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Ive got the mantec plastic jobbie and very pleased with it
Post #313685 5th Mar 2014 9:42am
landy andy
Having now brought and fitted both mantec and a safari I can definitely say test the safari is by far the better product. Better quality, great clear instructions, with loads of photos, all required parts supplied, clear instructions on how to seal the rest of the system so it's a snorkel not rai.
Very very nice product
Andy
Post #314819 9th Mar 2014 9:05pm
HMARR
Do you think the Safari would allow more air to be rammed down it (at speed) and therefor give you more horsepower? (Vs the Mantec which looks like it relies on sucking...) ???
Question
Post #315106 10th Mar 2014 9:49pm
landy andy
Air must be rammed down the safari, how helpful I'm not sure, but mine goes well with safari one fitted.
Andy
Post #315118 10th Mar 2014 10:11pm
