Home > Maintenance & Modifications > Chequer plate wing tops |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 856 |
Mine is cut larger for the top to be recessed.
28th Feb 2014 11:15pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Did you do it yourself
28th Feb 2014 11:18pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Most of the chequer plate wing tops have the holes cut bigger then the plastic covers.
Only Entreq (afaik) do wing tops where they mill the recess out so that the plastic plates sit flat into the recess. Mick, if you are after some wing tops give me a shout when you are close by. Brendan |
1st Mar 2014 12:09am |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
Mine too sits around the cover, rather than it sitting on top of it An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
1st Mar 2014 8:42am |
