Home > Maintenance & Modifications > Electrical part supplier |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
Vehicle Wiring products.
Mobile Centre I've used this chap on ebay for Thin Wall cable > http://stores.ebay.co.uk/Kojaycat-Vehicle-...7675.l2563 I guess it depends what you are after? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
22nd Feb 2014 11:15am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19621 |
VWP and here for thin wall: http://www.ebay.co.uk/usr/roddas73
VWP are good for bulk but small orders and individual items cost more on delivery. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
22nd Feb 2014 11:20am |
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 |
Thanks.
In this instance I am replacing light bar mounted spots with an LED lamp on the roofrack - I want to break into the wiring with a waterproof plug and socket so lamp/roofrack can be removed if necessary. And in general it's good to know a supplier who has quality components rather than cheap ones. Gavin |
22nd Feb 2014 11:24am |
A marine chandlers can be excellent for sourcing top quality cable for the harshest environments. Really depends on what your plans are and where the cables are going to sit.
Personally I use Olflex Cable from Germany and available from Farnells it is suitable for just about anywhere on the Land Rover and available in different core sizes and multicore. http://uk.farnell.com/jsp/search/browse.js...tid=229326 Cable Glands don't come much better than those offered by Index Marine. Side entry ones available too. http://www.indexmarine.co.uk/deck-glands-se-series.php Cannon, amphenol and just about any connector for any purpose PEI Genesis Southampton. You will of course need the tooling to crimp the pins sockets but I can possibly help you out as you're not a million miles away. 'PM' me if you wish I may have a few bits 'n' bobs lying around, dependant on your needs. http://www.peigenesis.com/en.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Feb 2014 11:26am |
Sorry gents I think I confused the issue by putting "wiring" in my original question - I meant wiring accessories and in this particular case an IP rated plug and socket to break into existing wiring.
Gavin |
22nd Feb 2014 11:45am |
BTW K9F - that Index Marine kit is quality.
22nd Feb 2014 11:46am |
Google 'Buccaneer 400 Seies IP Connectors' and take your pick.
http://www.ebay.co.uk/itm/3-PIN-400-SERIES...144wt_1197 http://www.ebay.co.uk/itm/Flange-mount-soc...1251wt_960 Or look here under connectors and scroll down to weatherproof..... http://www.vehicle-wiring-products.eu/VWP-...ectors.php If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Feb 2014 1:11pm |
Perfect - thank you K9F.
22nd Feb 2014 3:10pm |
