Home > Maintenance & Modifications > Battery options |
The original battery (dated March 2002) has finally given up the ghost. I have always thought I'd replace it with an original equipment one as the current one has lasted 12 years.
I have heard good things about the Bosch S5 range and am open to dual battery setups, although I'm not sure how much I'd utilise the functionality of a dual battery setup. Some suggestions would be most useful 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th Feb 2014 6:52pm |
Mud Dog Member Since: 11 Jul 2013 Location: Kent Posts: 31 |
Odyssey + 1 We're not stuck...just enjoying the scenery!
20th Feb 2014 10:20pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
I intend to replace mine when it eventually dies (it,s still on its original) with a Bosch/Varta agm 100 amp/hr. 2005 Td5 90 XS
Steve |
20th Feb 2014 10:26pm |
Thanks, pretty much what I'd expected. Going for a Bosch me thinks 2002 90 Td5 Station Wagon
20th Feb 2014 11:13pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Tayna sell batteries at competitive prices. Numax make good batteries.
http://www.tayna.co.uk/ Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
20th Feb 2014 11:26pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7705 |
my batts always come from Tanya (well the last 7 have) i use the Numax ones, great value good CCAs and Ahs for the money
Oddossey are good but over priced in my experience. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
21st Feb 2014 2:48pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
Mine's a numax from Tanya, would get one again, failing that I'd get the Bosch.
21st Feb 2014 5:28pm |
The one I had for my Series 2 was a CXV35MF http://www.tayna.co.uk/Numax-CXV35MF-P8275.html . It only just fitted in the space. I needed longer cables to allow routing to the terminals.
Have one again. Would it fit in a Puma battery space without any modifications needed? Are there any battery compartment depth extenders made for under seats. If strong enough they could also act as seat raisers. A similar RH one could be fitted to both raise the driver's seat & give more space for ECU protection (for example, thinking of shielding from water). Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
22nd Feb 2014 8:34pm |
similar to the ones i am running Cheers
22nd Feb 2014 9:35pm |
