Home > Maintenance & Modifications > How much for a new clutch in a TD5 110CSW |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 |
Just wanted to know if anyone could help me as I am after some quotes to change my clutch in a 110 CSW TD5. Its currently making a whirring sound when i put my foot down on the pedal before engaging gear and I think there is a bit of slipping near third. I think its the release bearing but it would make sense to replace the clutch at the same time!!
Can anyone give advise? |
17th Feb 2014 11:13pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
£800
17th Feb 2014 11:20pm |
Is that parts and fitted?
17th Feb 2014 11:27pm |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 |
with the flywheel as well? |
17th Feb 2014 11:39pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
17th Feb 2014 11:45pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Spigot bush noise is standard fit on a Td5 but don,t worry about it because when the fuel pressure regulator leaks the diesel runs down the back of the engine and into the bellhousing and lubricates it 2005 Td5 90 XS
Steve |
17th Feb 2014 11:51pm |
Yep, clutch & DMF was £800
17th Feb 2014 11:52pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
New spigot bushes don't squeal if you put a tiny bit of loctite on them when you put them in
18th Feb 2014 8:07am |
