Home > Maintenance & Modifications > Mushroom top replacement |
Zim Member Since: 25 Jul 2013 Location: Small Village, south side of Leicester Posts: 85 |
Bumpety Bump. Anyone have a rough idea? Anyone else ever replaced their mushroom top? 2007 Defender 90 XS
21st Feb 2014 3:53pm |
A manufacturer's make would be a good start perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
21st Feb 2014 3:59pm |
Unfortunately it has no brand on it. It was fitted to the 90 when I got it. I can only assume its a "no brand"? 2007 Defender 90 XS
21st Feb 2014 4:00pm |
If the replacement are only 64mm not only would you have to sleeve it to the extent of 13mm but you would also have to seal it to prevent moisture ingress too. Stick up a photo and someone may be able to help from seeing it and recognising the make.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
21st Feb 2014 4:02pm |
Here is a picture I took a few days ago:
Click image to enlarge As you can see there is a rubber gasket between the mushroom top and the pipe which runs up the windscreen. The mushroom top sits over the rubber gasket, and has a sleeve which tightens around both with a bolt. I can take more pictures if it will help? 2007 Defender 90 XS |
21st Feb 2014 4:26pm |
jhnstap Member Since: 01 Apr 2013 Location: Bournemouth Posts: 73 |
Is that an old Mantec Snorkel?-looks similar I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine
21st Feb 2014 4:41pm |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 856 |
Try your local tractor shop
21st Feb 2014 7:24pm |
