Home > Technical > TD5 problem, help please |
RichyB1967 Member Since: 16 Feb 2014 Location: Dundee Posts: 11 |
Thanks Laurie,
Will look into buying a battery tomorrow. Richy |
16th Feb 2014 5:45pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Ideally get an OE one or a good rated equivalent.
16th Feb 2014 5:48pm |
Does anybody know if the power relay energises when the engine starts only?
16th Feb 2014 5:56pm |
My connection on the solenoid was very loose and occasionally prevented the starter motor from working but couldn't possibly cause Richy's problems.
16th Feb 2014 6:37pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
Sounds like power control relay has an earth issue, tried cleaning the earth inside the seat box? There's a black wire with a ring terminal that bolts to the bottom, this can cause issues. The last one I had this issue on was due to a broken earth wire between the inertia switch and the main relay, cured with an overlay harness
16th Feb 2014 7:26pm |
There's a grommet on the front inside wall of the seatbox.
Originally this had wire running through it to attach an earth wire from the ECU to the engine (bellhouse flange) This was dropped in later models. It's worth reinstating. |
16th Feb 2014 7:32pm |
Solved it, the earth or ground was poor to the body. I was getting high resistance between the neg term on the battery to the chassis, and used a jump lead to the seat box to establish a good connection, and it started first time. Thanks for all the advice. I now need to reconnect the earth from the tow connector as it had failed.
19th Feb 2014 4:15am |
