Home > Maintenance & Modifications > Headlamp Levelling Motors |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4502 |
When my 2008 was purchased new, the headlamps would always come on pointing at the ground very close to the vehicle. After driving for a while the motors would operate of their own accord and raise the lightbeams up to normal levels. When the ignition was turned off the lights would go back pointing low again. The motors were changed under warranty and everything worked well after that. Nobody else seemed to have this problem but faulty motors would not be unknown. 1982 88" 2.25 diesel
19th Feb 2014 12:39am |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
Stating the obvious - but did you unplug/disturb the connector onto the motor?
19th Feb 2014 1:30am |
