Home > Tdi > Pre 200/300 tdi engine reliability? |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Assuming its the 2.5TD then its not the finest engine ever made. Having said that, if its survived this long then it will probably be one of the good ones. If you can find Defender 200 tdi then it will drop straight into it when that engine does pack in. If the rest of it is in good nick then dont let the engine put you off, its far easier to change a engine than a bulkhead or the chassis.
Pete. |
13th Jan 2014 9:52am |
landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134 |
Above post my thoughts exactly when I bought a 1989 90 last year for knocking about in. The one you're looking at will be a 2.5 TD for that year (assuming original engine!), allegedly not the best engine, but the one in mine has been great, no problems with it (Ok, it's not a Puma!), but fine for trundellng about in, uses no oil/water, and no leaks!!
The reason I bought this was cos the rest of it was very sound - great chassis/bulkhead, and everything worked on it, only needed a bit of cosmetic tidying. As Zinke says, the later 200tdi will drop straight in if the TD engine ever goes - but while its still working good, I'll leave as it is! 1959 Series 2 Ragtop 1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS |
13th Jan 2014 12:37pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Thanks both for the above replies, it is a TD engine that's fitted, which is the original unit, after speaking to the person who's done the chassis exchange the chassis etc, he said he'd used the vehicle himself as a run-around before doing the chassis, new door bottoms, bulkhead etc etc, almost everything is perfect on it, just as I'd have done it, but the engine is the weak link, seems a shame to have gone to all that trouble and then not put a 200 or 300 tdi engine in.
Anyway, still thinking about it before parting with my hard earned! Thanks again. |
14th Jan 2014 12:11am |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
If it was me I would defo fit a tdi twice the power with better mpg worth thinking about Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
20th Jan 2014 7:27pm |
