Home > Off Topic > Garage walls |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 856 |
carpet on the walls where the doors touch, simple, cheap and effective!
8th Jan 2014 4:41pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Go for 1
For 3 you used to be able to get rubber bumper for door edges. Or consider something like an old 10mm foam sleeping mat/neoprene rubber fixed to the wall to protect door edges. A lot cheaper and quicker then dry lining. Brendan |
8th Jan 2014 4:43pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Leave the car outside.
Turn it into a workshop/bolthole. Cover walls with posters of half naked young ladies. PS Don't forget the beer. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
clean it
leave existing paint on walls but scrub off loose bits carpet on wall where doors open keep defender outside use garage as a work room and when necessary for repairs BM52 |
8th Jan 2014 4:59pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
Don't think I need to comment as those above have answered it well for you
8th Jan 2014 8:46pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Insulate it,wood burner in the corner, cheapo wood laminate floor, old leather sofa,TV,fridge =MANCAVE!
(not forgetting workbench and tools). Pov.spec,ftw. 2006, 110,TD5. |
8th Jan 2014 9:19pm |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
What do you want to do with the garage when it's done?
If it's to store a car then it just has to be dry and airy, it you just want to have it looking good then the wire brush/paint will be fine. If it's something more detailed then you're into rendering the walls and plastering over it. It all depends where you want to end up. |
8th Jan 2014 10:13pm |
Birdy Member Since: 07 Oct 2011 Location: CĂ´te d'Azur Posts: 855 |
“present a hard surface to opening car door edges”
So? A bit of paint on a door edge may/may not be scraped off? A touch-up brush will work out cheaper than dry-lining, skimming, skirting boards, painting etc. Whitewash the walls and a couple of strategically placed carpet tiles, job done… Peter |
8th Jan 2014 10:26pm |
defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411 |
Thanks all, the balance of opinion is clear.
It'll be the cheap option then, scrape and paint - and I've got plenty of bits of carpet underlay, so that's car door protection dealt with as well. Rob |
9th Jan 2014 11:07am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Can you use a compresor & spray gun to apply masonry paint? It'll speed up the process a lot? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
9th Jan 2014 11:33am |
Good thought Martin, I had considered spraying but then there's always the cost of hiring equipment etc. and since I am retired, time and speed are not of the essence.
9th Jan 2014 11:38am |
