![]() | Home > Maintenance & Modifications > Bonnet protection |
Pretty sure there is only one manufacturer of one piece Puma bonnet chequer plate and that is Mammoth.
Available from forum sponsor MPS Trading (SGH) We've got it fitted to the FCX 130 and it seems good quality |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 ![]() ![]() ![]() |
No Problems with Mammouth, excellent kit. I fitted my wing cp with foam gaskets.
Mammouth is good quality. You get gasket supplied and I used Sikaflex to seal up afterwards. If you're bonnet's not fooked now after drilling 28 holes to fit it it will be....
![]() The photos are long gone but here was my fitting guide.....
![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Just got a Mamouth 4x4 trading Pumatech bonnet cover. They don't come with foam (I'm sure the last one did.. Go Beyond????)
Anyways I drilled more holes (and countersunk them) to get a better fit. Nothing that wrong with the standard fitment I just wanted it better ![]() Oh and I swapped the bolts for stainless ones ![]() |
Andrew,
Mine came with foam gaskets and stainless bolts? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
I love the one piece from mamoth but at the cost I can replace my bonnet for a colour matched one and have change for some ale after so I havent bought it. It is a very pricey item but I do want one lol
£270 and you can get a bonnet swap? Where from?
Yes Andrew it has foam
Thanks for the nod...... Right I best get on the phone then
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
That is a great looking 90....everything on the front seems to, "fit". Pickles. |
