Home > Puma (Tdci) > VCV - vapour control valve? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6266 |
as mentioned before I'm no mechanic / diesel / combustion engineer.....
but I'd like to try and understand what the above part does because it almost seems like an un-necessary sensor when you consider there's a fuel rail pressure sensor? so what does it measure and how does that affect other aspects of the fuel delivery system? |
23rd Dec 2013 2:31pm |
Lorryman100,
should have guessed you'd be along to enlighten me. many thanks. all I can say is have a great Christmas. |
23rd Dec 2013 3:21pm |
so map sensor and vcv replaced. injector learn and pump all done.
no obvious improvements, certainly my intermittent 'knocking / injector noise' hasn't gone completely. gave the MAF sensor and electrical connectors and wiring a good clean and wiggle last night..... this moring the engine seemed very lively....almost like it was running away with itself (compared to what I'm used to) so it looks like next move is a MAF sensor......... £150 from Ford seems Ford are cheaper for some things and more for others |
27th Jan 2014 9:25am |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 |
For your sanity I would get rid
27th Jan 2014 9:47am |
when you say injector learn done what do you mean? because when you get a new injector the code for it is on a sticker with it in the bag or on the side of injector .. where did you get the codes for injectors? |
27th Jan 2014 10:20am |
codes are injectors themselves.....now copied and kept with my service manual.
- get rid of..........where's the fun in that? |
27th Jan 2014 10:25am |
ok
was it about a 16 digit code copied off the injector .did you take injectors out ? |
27th Jan 2014 10:27am |
yes I believe it was a 16 digit.
injectors were not removed......I seem to recall some stickers where still in place?? |
27th Jan 2014 10:57am |
ok .. some did have a large sticker on timing case with the codes on it ..
with our machine you code injectors in firing order 1 2 3 4 = 1 3 4 2 if that makes sense also to be honest sometimes we have coded injectors and it makes them run worse we fit injector test run it first before coding if all good leave it as I said sometimes it makes them worse does it make noise s when you first start or how long into jornney ? is it after car has been standing for a while like days ? |
27th Jan 2014 11:44am |
to be honest it varies but this morning is not unusual.....
ie when I first pull off the engine sounds smooth even tho cold and been standing a few days, the engine kind of feels like it wants to 'run away', like its got a manual choke but then others times (usually when warm) it feel like the complete opposite.....as if its running too lean ? gave the MAF a good clean last night with electrical contact cleaner. seems hugely better but firstly not sure if it'll be back to its 'normal' self later and secondly did jiggling the wires make any difference (often been one of my suspects) ? |
27th Jan 2014 1:05pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
Aren't MAF sensors about 40 quid?
I put in an OEM one and it's been fine for 18 months: http://www.lrdirect.com/MHK501040-Sensor-A...3godm04Aag Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
27th Jan 2014 1:27pm |
hence I didn't buy it from Ford.
27th Jan 2014 2:08pm |
27th Jan 2014 3:08pm |
does it run fine if you use it everyday?
27th Jan 2014 8:28pm |
