![]() | Home > Td5 > Starting issues |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
When was it last serviced?
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
Injector O rings and copper washers.
My 90 did this (with the old cracked head on), and when I replaced the seals, it started much better. |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
In mileage terms, less than 3k, in time a good few years.... Cheers Simon |
I'd give it a good service first and if it still happens try injector seals and washers as said above
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
It might just be worth having a check on the air bleed valve found on the top of the filter housing behind the drivers side back wheel. Just pop off the front left fuel line and unscrew the pipe tail out of the body(19mm spanner) and see if you can blow/suck through it. If you can't either replace it/open it up and clean it or just leave it out to check. If you can blow through then I'd be tempted to get the injector seals and washers replaced.
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
Similar symptoms to my Disco TD5, and that was the injector seals.
Worth checking first that there's no air getting into the system any other way... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Thanks all, will give those ideas a try later.
Cheers Simon |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
have a look at the fuel pressure regulator located at back end of head, are there any small diesel leaks ?
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
I would agree with the injector seals as we had a similar problem with a disco 2 at work a couple of weeks ago, has it only done it since it got cold ? if so is the ambient temp sensor in the air filter box o.k ? 2005 Td5 90 XS
Steve |
Seems to be happening more often in the cold weather, but started ok this evening and it's pretty cold here.
Re: injector seals, if one or two are leaking would it not just run rough rather than not fire at all..? I've ordered some seals, but just trying to get my head around the symptoms. Cheers Simon |
| 238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233
I had the same issues as you, gradually got worse and nearly left me stranded once, tried injector seals, new battery, fuel filter/housing, fuel pump, serviced, fpr check and clean filter, check ecu loom none of which made a difference, turned out to be a bad earth going to where the ecu, I just run a wire directly from the battery to where the earth is under the ecu and it was fixed and cost nothing, worth a try before spending loads like I did
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Make sure you get genuine seals, there are plenty out there being advertised as genuine but are fakes.
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
My suggestion would be to try the prime procedure before starting, if it then starts ok after the prime I would change the injector seals.
Mine failed over night. Went from first spin starting to non starter in a night. New injector seals, all good. Andy |
Will check that, it does feel more like an electrical issue rather than fuel, but who knows... Cheers Simon |
| All times are GMT |
