Home > Puma (Tdci) > I need to share this with you..... |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6265 |
its been along time coming but at long last my defender is running better than I could have hoped for.
a recent service, replacement rear propshaft, replacement handbrake cable which involved pretty much rebuilding the handbrake drum and replaced MAP sensor and things are great. I'm now just understanding how smooth gear changes can be, realising you can crawl along in 1st gear without lurching forward and how its is possible to easily determine that the turbo does actually work..... its GREAT !! mechanically I just hope it continues. now to ensure the chassis doesn't rot around the wonderful mechanics. - I hope thats sold it to you cause its up for sale - please refer to topic for selling. only joking. there's no way I'm selling this now.....I'm just gonna enjoy it. next task (as well as anti corrosion) is to arrange my trip to Spain for a few days |
5th Dec 2013 10:53am |
Lots of local stuff so not too many miles
Sorry to hear things aren't going well for you... I hope you quickly find the solution. |
5th Dec 2013 12:41pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16892 |
I echo BM52's sentiments and I am really pleased that at last your troubles are over and your vehicle is right! I am sure that you'll find it was worth the effort.
I only wish mine was the same - like BM52 I seem to have picked up the gremlins you have purged!
It is spooky that I could have written the exact same thing! |
5th Dec 2013 12:58pm |
sorry that you're not having much fun at the moment and know how frustrating it can be.
if you are suspicous of the egr personally I'd consider putting the original map back on to see if the clean cycle is performed. with the egr shut is should be pretting clean and as such I've have though this would still work no probs. if it does and as mentioned before you can hear operate while reving the engine (or if you can install a blank) I would have though this eliminates the egr. still leaves loads of different things to check but hopefully the above basic test will eliminate the egr. if as reviewed before the fuel pressure is ok then then hopefully that eliminates the fuel to the engine. if there's no signs of leakage around the injectors and it runs smoothly (if only for a bit here and there) personal I'd say the injectors are ok. which would lead me to sensors and wiring. all very basic tests that I'd be looking to do - I'm not suggesting for one second the above is right but its just what I'd do. good luck.[/i] |
5th Dec 2013 1:19pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2070 |
Touch Wood!! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
5th Dec 2013 2:02pm |
Got my legs crossed too
5th Dec 2013 3:15pm |
5th Dec 2013 3:16pm |
That must be both of them then
5th Dec 2013 4:19pm |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
Thank god for that! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
5th Dec 2013 4:34pm |
yes both of them.....double post by accident due to over excitement
like you say 'thank god for that' ! |
5th Dec 2013 5:49pm |
Ha ha. How long before you imagine - sorry notice - a noise, vibration, loose or missing whatchyamecallit, tiny bit of corrosion or other mysterious somethingorother that will prompt a minor panic and flurry of posts Steve.
5th Dec 2013 10:05pm |
Now you mention it I fear there may be a whatchymacallit missing.....how many do you have?
Joking aside all is good and any more problems you'll be the first to know.....i have your pm details Hope yours is going well? I also have moved rot than I care for but it's just had a good dose of acf50. Hopefully next year a clean and dinitrol. Before that however I might get a drl bumper and roof rack. Upgrade of the stereo. Heated rear seats and inverter should keep me happy for a while. |
5th Dec 2013 10:25pm |
