Home > Puma (Tdci) > Intercooler upgrade after a remap? |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
Best person to ask is Pete him self drop him an email but I'm pretty certain if he has given your car the level of tune I think he would it would benefit greatly from an intercooler
Stevd 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
12th Nov 2013 7:46pm |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 609 |
A bigger Intercooler will always improve the engines performance, increasing torque, and allowing the engine to run cooler and more efficient.
A performance Intercooler also allows greater potential from the engine, which could be exploited with an appropriate remap. How much potential is used should be gauged depending on vehicle usage, condition, and personal preference. Regards, Gary |
12th Nov 2013 8:20pm |
The latest remap will compensate for a larger intercooler. I asked exactly the same question of Pete from BAS before committing to a remap from him, then I spread the custom and bought an intercooler from Gary at Alive. Hopefully it keeps everyone happy. I know with the results I certainly am!!!!
http://www.defender2.net/forum/topic13612....ntercooler If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th Nov 2013 8:26pm |
Ian Mac Member Since: 16 Oct 2013 Location: Essex Posts: 53 |
Thanks Gary and Steve
Steve i have sent him a email Gary, i understand the benefits and so on but I'm unsure wether the edu will compensate for the extra dense air and add the required fuel to compensate?? Also what other Mods can i carry out to get the best from the Engine? Many thanks Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
12th Nov 2013 8:28pm |
K9F
Thanks very much, I better find out if mines the latest version then as it was installed by someone else but developed by pete. Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
12th Nov 2013 8:30pm |
If it's been done in the last 5 months it should be the newest version
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
12th Nov 2013 8:33pm |
The ecu will be just fine, with a bigger Intercooler fitted.
As to what other mods you could fit, your best off talking to the person who did your remap (in your case, Pete), and discussing your precise needs. As I touched upon previously, there are loads of things that need to be taken into consideration, and there are loads off accessories available from many sources, all of which differ in their own ways. Regards, Gary. |
12th Nov 2013 8:43pm |
Many thanks Gary
I would like a Serck Intercooler as they seam good value. Are these recommended? I do a lot of towing long trips in the summer and a little off road use. Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
12th Nov 2013 8:50pm |
I had seck on my 2.4 before swapping engines and it was a very good cooler they have come down in price heavily since I bought mine though other option is allisport
12th Nov 2013 8:54pm |
a allisport works out roughly £120 more expensive than a Serck one so it the allisport worth the extra?
Thanks Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
12th Nov 2013 9:21pm |
Its personal preference the biggest thing is you will end up waiting for a allisport one as they are rarely in stick I'm afraid
12th Nov 2013 9:24pm |
They all do the same. If you want unquestionable quality go for one of these. I did quite a bit of research befor committing and they are very good.
http://www.alivetuning.com/alive-boutique/...duct_id=90 Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th Nov 2013 9:28pm |
I can't find the link but I have seen bad publicity about these k9f sorry if I'm wrong and I don't want an argument but Ido believe there over priced !
12th Nov 2013 9:39pm |
ITS MASSIVE!!! But i noticed the price too...... i see its nearly twice as expensive SO is it twice as good??
Pete has been great answering my questions this time of the evening! top class service!! I would recommend him 100% Thanks everyone ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
12th Nov 2013 9:49pm |
