Home > Puma (Tdci) > Foam pad front and rear door seals Defender |
On the first Puma's (2007-2010) the front and rear door seals had some glued foam pads which with many of us will have disappeared by now. The front foam pad reference I found from Britpart as per below link.
http://www.brit-car.co.uk/product.php/1086...r_seal_def I am pretty sure that on my 110, there were similar foam pads with the rear door seals which have come off, but I cannot find any specific reference anywhere for these rear foam pads. Are they the same item as the front door foam pads, or can someone point me in the right direction for these rear door foam pads? Some day I probably will replace the entire set of 4 door seals by the new type, but for now would just like to order the missing foam pads. Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
9th Nov 2013 8:04am |
we can talk to Philippe at autobritt later this morning
9th Nov 2013 8:17am |
We sure will do that, but still think I will have to be a bit more proactive to get hold of those foam pads myself.
See you later this morning, think we will be there by 11.30 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
9th Nov 2013 10:14am |
