- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
tatra805
as far as i know LR changed to grease long time ago. Yours should not have oil in the swivels but grease. If there was an oily substance in the swivels you probably have you diff oil migrating past the seals into the swivels. (seal part nr FTC3276)
In short, your grease will be oil again after some time. Did they check diff oil level? might be worth looking at it before the diff is "running dry".
2cents
9th Oct 2013 10:27am |
