![]() | Home > Maintenance & Modifications > Heated Washer Jets |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 ![]() ![]() ![]() |
There was a tip in LRO once about extending the washer hoses and running it alongside a radiator pipe or similar, slight pre-heat but probably not very effective. Might stop it freezing totally once we hit -20C
![]() 55 TD5 110 CSW Special Vehicle |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5093 ![]() ![]() ![]() |
Found the one - wrapped copper pipe around the exhaust manifold and around the jet pipe Mike
http://www.sigmaautomotive.com/HotShot/hotshot.php Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
That's pretty groovy. Have you fitted it yet ![]() + New Defender 110 First Edition |
No, my next project is the Webasto Top C
![]() ![]() IID Pro MV License |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
It will still freeze at the washer jets when its not in use with the windchill i would have thought.
i |
That product claims to clear the jets with steam. No idea whether it works or not. One that started out as a 2.4 TDCi 110 XS
Have you considered the effect of squirting hot liquid onto a frozen screen?
Hope your insurance is good. ![]() |
is that a roll back sunroof then d like they used to fit in the seventies ![]() 1968 1/32 scale Britains 109 Pick up. |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 ![]() ![]() ![]() |
I've got one of these fitted to a Nissan Patrol and it is brilliant at clearing the ice, however the idea that it can clear ice at the jets maybe overstating things.
It heats the water on the way from the tank to the jets so be aware that you need to ensure that the tank doesn't get frozen, once it leaves the hotshot it is cooling down in the tube to the washer jet so you need to ensure that your washer fluid wont freeze in those circumstances too. So at this point you have probably worked out that you need washer fluid that is always liquid which possibly defeats the idea of the hotshot. That said if the tubes have got a bit of ice it will clear it and it has an auto setting which fires hot fluid at the screen for a few minutes and clears the big screen on the Patrol and it does look cool to have steaming washer fluid clear the screen instantly. To the person that questioned whether it will crack the glass, I read that they thoroughly tested the unit in all conditions against all makes of glass. |
gnaa gnaa gnaa ![]() ![]() ![]() ![]() Click image to enlarge :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
I've just fitted one of these to the Defender, had the same concerns as Sticky but was sufficiently intrigued to give it a go - used it for the first time today. Have left the Defender out tonight so will see how it copes at clearing the windscreen tomorrow. Fitting was fairly straightforward though it took somewhat longer than the vidoe on Youtube! I'll aim to post some pics tomorrow. |
anyone got one of these http://www.kenlowe.com/pre-heaters/cars/index.html
I'm waiting for...... ![]() ![]() IID Pro MV License |
