Home > Tdi > Squealing chirping noise
Tia4
United Kingdom 1998 Defender 90 300 Tdi SW Cairns Blue
Just when I was beginning to think the 90 was behaving its self it's decided to start to make a strange squeal when under load does not do it all the time just comes and goes its coming from the front but not sure where any ideas or suggestions most welcome
Post #268275 21st Sep 2013 7:54am
I had the same on my 300tdi, it turned out to be the front pulley tensioner, could also check the aux belt for damage
Post #268279 21st Sep 2013 8:17am
Alex1976
I agree with the diagnosis of bpman - almost certainly the serpentine belt tensioner. They are about £50 for an OEM one and take about 2 minutes to change (just a 15mm nut and swap the units over) or if you want to save a few £ and take a bit of time you can buy just the bearing for about £6 and take the unit apart to swap it.
Post #268285 21st Sep 2013 9:07am
Tia4
Thanks for the replies how would I check the front pulley tensioner?
Post #268287 21st Sep 2013 9:09am
Alex1976
Take off the serpentine belt and then you can spin the tensioer pulley by hand and listen for any grumbling/sqeaking etc or see if there is any lateral movement in the pulley by holding it and trying to move it back and to. Without any load it may seem smooth and quiet - depends how bad it is.
Post #268293 21st Sep 2013 10:06am
Litch
Sometimes even a pefectly serviceable or brand-new belt & tensioner will make the same noise.
I have had this off & on since brand-new (300TDi) and also since replacing the belt & tensioner with (genuine Dayco) replacements at service intervals. More often than not it is silent but occasionally it makes the noise especially if it has been parked up for a few days.
You can confirm if it is the belt / tensioner by the old trick of sprinkling some French Chalk or talc on the belt, if that stops it then you have identified the cause of the noise. ONE LIFE, GET IT!
Post #268304 21st Sep 2013 11:56am
