Home > Puma (Tdci) > Grab handles |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5029 |
The handles on the car from new usually have some reinforcement behind them - can you not use the dash handle? Mike
3rd Jan 2010 10:14pm |
solmanic Member Since: 17 Aug 2007 Location: Brisbane Posts: 191 |
The only way I've seen handles installed over the front passenger's door is with the use of reinforcing brackets fixed under the trim edge, where the head lining has plastic pop-tabs. There is no reinforcing inside the headlining up where you would put the handle. Here is a link to the thread on our AULRO forum where it was discussed in detail with some pics of what others have done...
http://www.aulro.com/afvb/technical-chatte...ender.html 2007 Defender 110 1970 Alfa Romeo 1750GTV |
4th Jan 2010 2:30am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Apparently the grab handle above the door is the last place your arm should be in the event of an overturn as your arm will fly out the window and possibly trap you. That is why Defenders have grabs on the dash. This no doubt is after years of accident analysis.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
4th Jan 2010 10:59am |
jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172 |
Mine come from the Freelander. I have put 4: one over each passenger door, one ine the middle of the roof in the rear for the middle rear passenger. Perfect.
No idea how my mechanic did it, but it is very strong. Click image to enlarge Boldly going nowhere Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular. |
4th Jan 2010 12:36pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2284 |
Probably right, but the handle on the roof avoids you to hit the head against the frame or window. The other solution is to install a steering wheel Puma 110" SW ............................................................. Earth first. Other planets later |
5th Jan 2010 12:18am |
