Home > Off Topic > Inverter current draw
JJ
United Kingdom 1987 Defender 110 V8 Petrol CSW Corris Grey
Can anyone advise how long it would take to flatten a battery using an inverter.
I am at the Romsey show tomorrow and plan to use an inverter to charge a small Nexus 7 tablet using a 150w inverter plugged in to the 12v socket , the last thing I want is a flat battery at going home time.
I have a car as a static display but can't run the engine.
Thanks
John
Post #266362 13th Sep 2013 5:42pm
leeds
Not a question which leads to a simple answer.
OK a broad stroke calculation with lots of assumptions
Power = Voltage x current.
150/12 =12.5 amps
Now assuming that the 150 watts is the output power and that losses are 20% then current draw could be 15 amps (12.5 x 1.2)
Assuming you have a 68 amp hr battery then the invertor will work for a minimum of 4.5 hours. (68/15 =4.5 hrs)
Next question what is the current draw of your actual tablet?
Difficult to say but if a late model nexus then the battery is reported to last about 8 hours.
So chances are that if you take a fully charged late model Nexus then it should last all day. You could safely top up the Nexus from your invertor.
Another possibility if this is going to be a regular occurrance is a hyperjuice battery.
In summary you should be ok, but take your jump leads just in case you need to start another vehicle Razz
Brendan
Post #266377 13th Sep 2013 6:13pm
JJ
That is a very comprehensive and re-assuring answer, Thank you. Thumbs Up
Jump leads on standby.
Post #266414 13th Sep 2013 8:14pm
Lou Sparts
I,m no expert but is,nt the 150 watts at 240 volts as its on the output side of the inverter ?
I had a 400w inverter that you could plug into a ciggy lighter that has a 10 amp maximum and a 15 amp fuse and that never blew.
Confused ? I am. 2005 Td5 90 XS
Steve
Post #266426 13th Sep 2013 8:41pm
leeds
Whilst the invertor might be rated at 400 watts maximum output that does not mean it is actually supplying the maximum power.
It is probably a good idea for the maximum power required to be less then the actual maximum power output of the invertor.
Also the wiring and fusing to be capable of coping with the maximum output of the invertor.
A 12 volt power socket rated at 10 amps is capable of 120 watts.
Plugging a 400 watt invertor into it, means that there is a strong possibilty that you could overload the 12 volt socket and wiring.
The fact that you have not blown a 15 amp fuse basically means you have not drawn more then 180 watts.
Brendan
Post #266433 13th Sep 2013 9:18pm
leeds
Brendan
Post #266434 13th Sep 2013 9:19pm
leeds
Brendan
Post #266435 13th Sep 2013 9:19pm
leeds
Brendan
Post #266436 13th Sep 2013 9:19pm
Lou Sparts
This electrickery stuff confuses the hell out of me but why would a 400 watt inverter plug into a 10 amp socket that will blow a 15 amp fuse if you use even half of your 400 w max output ? 2005 Td5 90 XS
Steve
Post #266441 13th Sep 2013 9:28pm
Tiger
Am I missing something
Why would you not just use 12v to power the Nexus??
Post #266490 13th Sep 2013 11:17pm
Tiger
What advantage does an inverter do?
12v -> 240v -> 5v ????
why not just do
12v -> 5v ???
Post #266491 13th Sep 2013 11:18pm
JJ
It was a last minute plan and I didn't have a 12v connection for charging the tablet but I do have an inverter lying around.
All went well and no drama with a flat battery.
Post #266879 15th Sep 2013 1:13pm
