Home > Puma (Tdci) > Engine braking vs brakes |
Not sure I take all that.
Our Puma's surely don't have a jake brake. My Puma 2.4 does have an EGR, not sure if this reinforces the engine braking. The more recent Puma 2.2 has the by Wikipedia mentioned particulate filter, maybe on top of that also an EGR. (Not sure abt that). So even if the Puma 2.4 has an EGR which supposedly helps engine braking, the Puma 2.2 has the DPF which supposedly has a similar effect. So why does my Puma 2.4 with an engine compression of 17.5:1 have significant more engine braking effect than a Puma 2.2 which has a lower engine compression of 15.5:1 ? And why does a Puma 2.2 with that compression have significantly more engine braking than any gasoline car which usually have a compression of 8 to 10:1, but never more than that? I can only conclude that engine compression does have a big effect on the engine braking..... You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
7th Sep 2013 8:04am |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
Done a bit more research and it seems to come down to pumping losses.....as follows. Higher compression engines appear to have more pumping losses. Looks like there are many things at play here including turbo geometry, EGR, pumping etc.
RE: pumping losses - I'm thinking the heating effect when you put your finger over the end of a bicycle pump and squeeze - that heat (energy) is lost to air (water jacket) and the compressed air when released gives back less energy, thus engine braking....more compression, more heat generated and thus could be lost to cooling system and therefore more engine braking on high compression ratio engines.....seems plausible to me. But then what do I know? One of the better forum posts I could find below ~~~~~~~~ pumping losses: energy put into compressing the air in the cylinders heats the air up and some of this energy is lost. This means that the downward stroke as the compressed gas (but not burning fuel) expands is delivers less torque than the cylinders in compression, so there is net negative torque. This has a bigger effect in diesels because of higher compression and more air in the cylinder. engine friction: pretty straight forward. net negative torque. parasitic losses: oil pumps, alternators, water pumps, air con, brake servo vac pumps all require drive from the engine, so there will be net negative torque. So yes, of course a diesel engine will engine brake off throttle. And because of the pumping losses associated with compressing nigh on full cylinders, engine braking is normally greater in a diesel than a petrol |
7th Sep 2013 9:23am |
Whatever you say Steve
I only know one thing, my Puma 2.4 has the best engine braking I have ever experienced with any car. Going down a rather steep and long ramp into an underground parking in first high, it nicely does it steadily at slightly above tickover, and that without any braking at all. Don't see many others do that. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
7th Sep 2013 9:51am |
limbrickh Member Since: 05 Oct 2012 Location: Canterbury Posts: 20 |
Thanks for all the feedback! This has been really helpful.
I guess I'm slowly formulating a view on the best approach... Engine revving high when cold = bad for long term engine wear Heater on during descent = colder engine Sitting on brakes down long mountain descent = bad for brake wear Sitting on brakes for long mountain descent = increased risk for bad outcome 2.2 = less engine braking than other Defenders Land Rover engines = can take a bit more pain than others A gut feeling tells me getting down the mountain in one piece (rather than trying to preserve my engine for the long term) is most valid. So, taking on board all your input... I'm going to turn my heater off Warm up my engine before the descent Use engine braking (High second) Use brakes to stop speed building up Be prepared to use a higher gear (third) a bit more readily but only judiciously. Thanks everyone! |
7th Sep 2013 11:29am |
Common sense prevailing You never actually own a Defender. You merely look after it for the next generation.
7th Sep 2013 11:31am |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 855 |
VeeTee,
Nice pic, wish I could upload too. Especially as in June I didn't go down in my truck but a Morgan with no hood! Peter |
7th Sep 2013 6:53pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
Why can't you upload? Would be nice to see the pics of your Morgan Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
7th Sep 2013 7:03pm |
