Home > Maintenance & Modifications > Lost a Mud Flap |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
http://4x4overlander.com/entreq-products/e...ckets.html
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
11th Aug 2013 12:09pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
not sure thats what im needing, the whole bracket has been taken clean off, he flap itself is still very attached to the arm lol
11th Aug 2013 12:12pm |
infact on second looking that looks like its meant to reinforce the lip of the arch am i correct ?
11th Aug 2013 12:13pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2070 |
you got it! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
11th Aug 2013 12:16pm |
i am buying them bad boys !
thanks for the find bob neville thread closed lol |
11th Aug 2013 12:18pm |
Cat81 Member Since: 05 Mar 2014 Location: Kent Posts: 60 |
I just lost my 2 rear mudflaps (!) to the same issue. Wheel arch broke at the fixation point. This looks like a great solution although I am now worried to tear the whole thing apart.
Is it possible to fix 90 mud flaps to a 110 (the ones that go on the cross member)? |
28th Sep 2014 9:34am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Yes I would think it is possible to fit 90 rear mud flap brackets to a 110.
However because the rear mud flaps are now set back further then normal they may well not control water spray so effectively on a wet road. It may be a better idea to use the strengthening/repair brackets on the body panel and drill a small hole in the bottom of the rear mud flaps and attach a baby shackle etc and just tie the rear mud flaps up onto rear bumperettes etc. when going offroad. Brendan |
28th Sep 2014 10:03am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5422 |
Or buy Gwyn Lewis reinforced quick removal mud flaps. That's my plan.
http://www.gwynlewis4x4.co.uk/product/defe...quare-tub/ Andy |
28th Sep 2014 11:21am |
Thanks Brendan that sounds like a plan. Andy, these are nice, but also ... 100+ quid!
28th Sep 2014 10:02pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Happens the same to me several years ago.
1st try to straighten the tab were the mudflap is attached. Buy a L shape 20x20x1 mm aluminium, cut in a +/- 150 mm long make an hole to put again the bolt and rivet or bolt it to the tab of the panel in 4 points. 1/2 hour work. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
28th Sep 2014 11:58pm |
