![]() | Home > Technical > Mystery creeking / banging noise ? Help |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279 ![]() ![]() |
Heavy duty and noisy creeking / banging coming from drivers bulkhead / floor / steering area . Ever since i pulled a BMW out of the ditch last snowfall . I was giving big hard yanks from the drivers side chassis point . It sounds structural , and comes from floor area so bulkead - chassis or steering area - chassis ? Now its so bad at 60 mph the whole front end has a severe wobble right through to the steering and my legs . What the hek could this be ? Its driving me insane . I cant find a single loose part . Every turn and bump its horendous . Any ideas ?
Big hard yanks? Enough to make it jump around? Have you checked to see if the front springs are seated correctly? Failing that, you've pulled something out of alignment. Not sure what you mean by 'chassis point' but the standard towing eye isn't designed for hardcore recovery abuse. Darren
Thanks for replys yep something is definetly out of shape but i have checked the springs . The steering relay and unit are bolted directly to the chassis and in the place of all the probs and noises . Also how and where is rhe bulkhead mounted to chassis at the drivers footwell side ? Its permanently like this on every turn of rhe wheel and corner and bump . You know the noise a wooden ship would make on a rolling high sea ? Then thats it . Structural .
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Front hockey stick rear bush
whoops
Im ![]() |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 ![]() ![]() ![]() |
The bulkhead is bolted to the chassis below the front door pillar behind the sill.
The hockey stick is the term used for the front radius arm because it's shaped kinda like a hockey stick where it is bolted to the front axle. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
sorry how old is your tuck?
could you have damaged the chassis / crack somewhere (hopefully not - especially if its relatively new) I hope its nothing too serious but from what you've said I'd with with chassis and work back from that ie everything that bolts to it. good luck. |
Ok the 110 is 2012 2.2 110 . JR your explanation is spot on buddy and sounds exactly right to my area of probs . I know i was tugging hard but find hard to immagine the chassis with a crack in it . NEVER again helpin a spotty teenager in a BMW . Cheers boys for your help , i will keep you posted as to the outcome .
Ok both Ibexman and JR
Aaarragh ! Premature excitement
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18033 ![]() ![]() ![]() |
That is a bit worrying, seeing that Landrovers haven't had steering relays since leaf spring days! Sorry you still have your noise, though. |
With a big smile on my face yes you are right . Takes me back 15 yrs as i remember Trying to get a steering relay out of my 1966 S2a , with a great big hammer and a blow torch it took about an hour of heat and destruction for it to move . Ahhhhhhhh
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 ![]() ![]() ![]() |
I had a similar prob with previous Def when I was recovered from a rather large mud hole. I had a noise and a death wobble at speed - eventually traced it to the fact the panhard rod weld had sheared - worth a quick look just in case. Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
