Home > Puma (Tdci) > Grinding noise |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
sounds like the diff 2.4 90 XS
14th Dec 2009 1:03pm |
Niel Member Since: 14 Sep 2009 Location: Sandton Posts: 27 |
my "new" diff is making that same grinding noise. The old one never used to Puma 110 sw White
No extras yet. |
14th Dec 2009 2:47pm |
it could need setting up properly to much back lash perhaps 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
14th Dec 2009 3:50pm |
felos Member Since: 24 Nov 2008 Location: Athens Posts: 12 |
It's the rear propshaft,nothing serious if you can stand the noise.The only cure is to change it with a TD5's one (from the "SALISBURY" rear Diff model). NOT A TRANSIT
14th Dec 2009 5:57pm |
austen Member Since: 11 Mar 2008 Location: Sydney Posts: 52 |
I get this noise too. Can't say if it is less noticeable on a bend, but if this were the case it could indicate a diff.
Mine does it especially on a long journey when backing off the throttle between 100 - 120kph. It won't do it below 100kph. Comes from the centre/front. I have told the dealer who claims not to be able to hear it. Austen Rover 12 1935 Rover 20 1940 Rover 100 1960 Defender TDC1 2008 FL2 TD4 2008 |
14th Dec 2009 11:55pm |
