Home > Puma (Tdci) > Softer ride
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Softer ride
My 90 CSW has HD springs on the back and the ride is a little choppy. The majority of my miles are on road with the vehicle empty unless my 2 young daughters are in th back so looking for a smoother ride.
I have done a little searching that has revealed Koni shocks tend to be well regarded. My budget is limited so what's recommended?
Rear shocks first or softer springs? And which ones?!
(If I fit koni etc would I need to change the fronts at the same time?)
Darren Darren
Post #254423 29th Jul 2013 5:41pm
geobloke
Re: Softer ride
Darren
Hi Darren. Are your springs Land Rover or aftermarket? The colour coding for standard LR springs on the rear of a 90 are;
HD - Drivers side - green/yellow/red - Dual rated at 210 then 240lb
HD - Passenger side - green/yellow/white - Dual rated at 210 then 240lb
SD - Drivers side - blue/red - 225lb
SD - Passenger Side - yellow/white - 225lb
I would confess openly that I have just switched from HD +2" springs all round on my 110 to Standard LR springs (dual rated front and back) and the ride is amazingly comfortable now. The shocks remain the same, in my case Old Man Emu, the ride quality is vastly improved and I still carry the heavy loads I used to with the HD springs with no problem.
If you are truly running HD springs then I would first look at the springs, a full set will not set you back all that much. IIRC I got mine off the bay for £50 with only delivery mileage on them Smile
Post #254427 29th Jul 2013 6:02pm
DarrenJ
I did check when I first the got the car and its heavy duty rear springs, all standard LR set up. Darren
Post #254443 29th Jul 2013 7:13pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
I put a Terrafirma +40mm kit on my 90 and the rears were softer than the original Disco 1 set that came with the motor, more balanced too.
I believe they do a standard ride height set too. I'd highly recommend them, especially for the price.
Post #254466 29th Jul 2013 9:25pm
farmer giles
i have found that replacement dampers improve the ride far more noticeably than springs do.
if possible replace all 4 dampers for koni, bilston, de carbon or OME to improve the ride.
Post #254556 30th Jul 2013 9:37am
