Home > Technical > Electric Window fault |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
Any more info than "a fault"? That's a bit vague! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
21st Jul 2013 4:55pm |
Probably a snapped wire in the rubber boot between the door and post
21st Jul 2013 5:05pm |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 150 |
Won't go up or down....I've put a separate supply on motor which worked, swapped fuse and swapped switches over with each other.
So I suspect either a break in the loom or could there be another connection somewhere that may have come adrift? |
21st Jul 2013 5:06pm |
Almost certainly a break in the wires leading to the door as mentioned above. It's a common fault. Darren
21st Jul 2013 5:21pm |
Yep.... that was it.... a broken red wire in the rubber boot....cheers for your assistance
21st Jul 2013 6:39pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2159 |
Drivers window stopped today .
Forget using the solder iron as the solder won’t take to the cheep LR wiring of the loom . Managed to make the incision in the exact right place and guess what I found ? Notice the blue also on the way out so both repaired with extended length of new wire. Click image to enlarge |
14th Nov 2017 10:43pm |
It must be the cold weather as my central locking stopped working on my drivers door last night but worked again this morning Ray
14th Nov 2017 11:18pm |
Cold weather never stopped a Landrover
It’s positively balmy up here and I got eaten by midges whilst changing out the wires . Keith |
14th Nov 2017 11:22pm |
Cold weather stops mine, I'm sure it's snow shy as its broken down twice the week the snow started and it must be getting nervous now we've had a couple of frosty mornings hence the broken locking Ray
14th Nov 2017 11:25pm |
I'm glad it was an excellent summer when mine went pear shaped, had to drive all the way home from Scotland with the window fully down
15th Nov 2017 9:11am |
