Home > Puma (Tdci) > Add "Ceramic Power Liquid Gearbox" to my MT82 gear |
CPL Gerabox .
Mates, done today, TRY IT, IT'S LIKE A DREAM, I to II and II to III like butter, a miracles!!!! It's ceramic additive, the best!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
28th Nov 2009 5:40pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4473 |
How much did you add and did you need to remove any of the existing stuff first? 1982 88" 2.25 diesel
29th Nov 2009 5:14pm |
It's necessary to add a 125 cc bottle (quantity for up to 3 liters of oils).
I change completely the oil (Castrol BOT328, 2,3 liters) but you can add CPL on the existent oil..... One treatment it's good for 100.000 km..... It cost 40€ (36-37£). If you change the gearbox oil remember that the fill hole IT IS NOT THE MAXIMUM LEVEL (like diff. and transfer box) , you need to fill the correct quantity (2,4 liters) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
29th Nov 2009 7:50pm |
Yes, on the manual is explained this, but I measure my drained oil and it was 2,35 liters, so I added additive and oil for a total of 2300-2350cc + or - Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
30th Nov 2009 10:17pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2586 |
Daniele,
What are the long-term results of using this? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
14th Oct 2011 11:00am |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 |
Lets' hope their product is better than their website...
So, how and where do we buy this stuff? I'm tempted to try it in the gearbox of my racing Alfa, too. 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
14th Oct 2011 2:53pm |
I have 68000 km now and the results are simply GREAT!!!!
smooth gear change, no noise, .......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Oct 2011 3:10pm |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
Cn itbusd in the tranfur box also? |
14th Oct 2011 3:51pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
I added it to my Puma at 3000k because of initial rough changes (risking warranty...) and it certainly made an improvement. Then drove 3000k around Italy and everything was great. However, when we got back and I tried to get my handbrake fixed (3 times!) a vindictive of a German LR mechanic half trashed my gearbox, so now I have had to flush it out again in case I need the gearbox replaced
Anyway, enough of my sob-stories - I can recommend it because I know it worked for me Matt p.s. it is really obvious when you drain the oil - looks like liquid bronze... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
14th Oct 2011 6:19pm |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
I have always used a ptfe bassed addative Nulon from Australia bloody hard to get hold of in the UK now. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
14th Oct 2011 10:42pm |
